[postgis-tickets] r14712 - Mark ST_ClusterWithin and	ST_ClusterIntersecting as taking geometry sets
    Regina Obe
    lr at pcorp.us
    Sat Feb 27 00:10:37 PST 2016
Author: robe
Date: 2016-02-27 00:10:37 -0800 (Sat, 27 Feb 2016)
New Revision: 14712
   branches/2.2/doc/reference_measure.xml
   branches/2.2/doc/reference_processing.xml
(so they are flagged as aggregates)
Move them to measurement and relationships section so matches 2.3 docs
Modified: branches/2.2/doc/reference_measure.xml
--- branches/2.2/doc/reference_measure.xml	2016-02-27 08:05:34 UTC (rev 14711)
+++ branches/2.2/doc/reference_measure.xml	2016-02-27 08:10:37 UTC (rev 14712)
@@ -1032,6 +1032,113 @@
 	  </refsection>
 </refentry>
+    <refentry id="ST_ClusterIntersecting">
+      <refnamediv>
+        <refname>ST_ClusterIntersecting</refname>
+        <refpurpose>Aggregate.  Returns an array with the connected components of a set of geometries</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
+            <paramdef><type>geometry set </type> <parameter>g</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <title>Description</title>
+        <para>ST_ClusterIntersecting is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents an interconnected set of geometries.</para>
+        <para>Availability: 2.2.0 - requires GEOS </para>
+      </refsection>
+      <refsection>
+        <title>Examples</title>
+        <programlisting>
+WITH testdata AS
+  (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
+		       'LINESTRING (5 5, 4 4)'::geometry,
+		       'LINESTRING (6 6, 7 7)'::geometry,
+		       'LINESTRING (0 0, -1 -1)'::geometry,
+		       'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
+SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
+--result
+st_astext
+GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
+GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
+        </programlisting>
+      </refsection>
+      <refsection>
+        <title>See Also</title>
+        <para>
+          <xref linkend="ST_ClusterWithin" />,
+        </para>
+      </refsection>
+    </refentry>
+    <refentry id="ST_ClusterWithin">
+      <refnamediv>
+        <refname>ST_ClusterWithin</refname>
+        <refpurpose>Aggregate.  Returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry[] <function>ST_ClusterWithin</function></funcdef>
+            <paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</para>
+        <para>Availability: 2.2.0 - requires GEOS</para>
+      </refsection>
+      <refsection>
+        <programlisting>
+WITH testdata AS
+SELECT ST_AsText(unnest(ST_ClusterWithin(geom, 1.4))) FROM testdata;
+--result
+st_astext
+        </programlisting>
+      </refsection>
+      <refsection>
+        <para>
+          <xref linkend="ST_ClusterIntersecting" />,
+        </para>
+      </refsection>
+  </refentry>
   <refentry id="ST_Contains">
 	  <refnamediv>
 		<refname>ST_Contains</refname>
Modified: branches/2.2/doc/reference_processing.xml
--- branches/2.2/doc/reference_processing.xml	2016-02-27 08:05:34 UTC (rev 14711)
+++ branches/2.2/doc/reference_processing.xml	2016-02-27 08:10:37 UTC (rev 14712)
@@ -3374,115 +3374,11 @@
 		</para>
 	  </refsection>
 	</refentry>
-    <refentry id="ST_ClusterWithin">
-      <refnamediv>
-        <refname>ST_ClusterWithin</refname>
-        <refpurpose>Aggregate.  Returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</refpurpose>
-      </refnamediv>
-      <refsynopsisdiv>
-        <funcsynopsis>
-          <funcprototype>
-            <funcdef>geometry[] <function>ST_ClusterWithin</function></funcdef>
-            <paramdef><type>geometry </type> <parameter>g</parameter></paramdef>
-            <paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
-          </funcprototype>
-        </funcsynopsis>
-      </refsynopsisdiv>
-      <refsection>
-        <title>Description</title>
-        <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</para>
-        <para>Availability: 2.2.0 - requires GEOS</para>
-      </refsection>
-      <refsection>
-        <title>Examples</title>
-        <programlisting>
-WITH testdata AS
-  (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
-		       'LINESTRING (5 5, 4 4)'::geometry,
-		       'LINESTRING (6 6, 7 7)'::geometry,
-		       'LINESTRING (0 0, -1 -1)'::geometry,
-		       'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
-SELECT ST_AsText(unnest(ST_ClusterWithin(geom, 1.4))) FROM testdata;
---result
-st_astext
-GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
-GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
-        </programlisting>
-      </refsection>
-      <refsection>
-        <title>See Also</title>
-        <para>
-          <xref linkend="ST_ClusterIntersecting" />,
-        </para>
-      </refsection>
-    </refentry>
-    <refentry id="ST_ClusterIntersecting">
-      <refnamediv>
-        <refname>ST_ClusterIntersecting</refname>
-        <refpurpose>Aggregate.  Returns an array with the connected components of a set of geometries</refpurpose>
-      </refnamediv>
-      <refsynopsisdiv>
-        <funcsynopsis>
-          <funcprototype>
-            <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
-          </funcprototype>
-        </funcsynopsis>
-      </refsynopsisdiv>
-      <refsection>
-        <para>ST_ClusterIntersecting is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents an interconnected set of geometries.</para>
-        <para>Availability: 2.2.0 - requires GEOS </para>
-      </refsection>
-      <refsection>
-        <programlisting>
-WITH testdata AS
-SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
---result
-st_astext
-        </programlisting>
-      </refsection>
-      <refsection>
-        <para>
-          <xref linkend="ST_ClusterWithin" />,
-        </para>
-      </refsection>
-    </refentry>
 	<refentry id="ST_UnaryUnion">
 	  <refnamediv>
 		<refname>ST_UnaryUnion</refname>
