[postgis-tickets] [PostGIS] #3477: topology regress failure on Winnie
trac at osgeo.org
Sat Feb 27 00:42:39 PST 2016
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.0
Component: topology | Version: trunk
Keywords: windows |
Okay this must have been something done in last couple of days.
Unfotunately the tranuk of both Winnie and Debie were failing because of
the sfcgal snaffu so I'm just seeing this issue now and it only seems to
be on winnie.
PostgreSQL 9.5.1, compiled by Visual C++ build 1800, 32-bit
Postgis 2.3.0dev - r14711 - 2016-02-27 08:06:33
scripts 2.3.0dev r14711
GEOS: 3.5.0-CAPI-1.9.0 r4090
PROJ: Rel. 4.9.1, 04 March 2015
regress/st_addedgemodface .. failed (diff expected obtained:
/projects/postgis/tmp/2.3.0dev_pg9.5_geos3.5.0_gdal2.0.1w32/test_14_diff)
--- regress/st_addedgemodface_expected 2016-02-24 13:20:49 -0500
/projects/postgis/tmp/2.3.0dev_pg9.5_geos3.5.0_gdal2.0.1w32/test_14_out
2016-02-27 03:11:04 -0500
@@ -168,7 +168,7 @@
T29|E34|55|9|35|16
T29|E55|-21|19|35|17
ERROR: Corrupted topology: adjacent edges 6 and -21 bind different face
(1 and 0)
-ERROR: Side-location conflict: new edge starts in face 1 and ends in
face 0
+ERROR: Side-location conflict: new edge starts in face 64d and ends in
face 64d
F17|{3:17,3:35}
F3,F4|{3:3,3:4,3:10,3:16,3:17,3:35}
F5,N4|{1:4,3:5,3:11}
Seems to be that hideous PRiD64 formatting thing raring its head again.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3477>
