[postgis-tickets] [PostGIS] #3390: Compilation under Alpine Linux 3.2 gives an error when compiling the postgis and postgis_topology extension
trac at osgeo.org
Sat Jan 2 22:10:56 PST 2016
Reporter: boonen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by robe):
boonen,
I can't replicate the issue you are having, but based on what you said, I
moved the perl definition below include $(PGXS) as you noted. It still
works for me. I've only done this for our trunk (2.3).
Can you give trunk a try. My assumption is that what we determine for
PERL is right and it's just PGXS overwriting the variable we set causing
the issue in extension install.
If I get positive feedback from you and our bots are okay with the change,
then I'll backport to 2.2.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3390#comment:3>
