[postgis-tickets] [PostGIS] #3390: Compilation under Alpine Linux 3.2 gives an error when compiling the postgis and postgis_topology extension
trac at osgeo.org
Sun Jan 3 10:34:06 PST 2016
Reporter: boonen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by gdt):
I've had a similar issue, which I think has been discussed on the list.
In pkgsrc, the issue is that the build of base postgresql does not depend
on perl, and therefore perl in pgxs is missing. One can argue this is
broken, but the basic problem is that packages that depend on many things
and can reasonably be split into pieces are difficult to deal with and
there are no truly good solutions, other than upstream splitting them.
I have replaced $(PERL) with @PERL@, but the notion of setting PERL=@PERL@
so that it is definitive vs pgxs sounds sensible too.
Arguably postgis should either look for perl and always use @PERL@, or not
look for perl and insist on pgxs being right. I prefer postgis looking
for it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3390#comment:4>
