[postgis-tickets] [PostGIS] #3415: fails to build on OS X because of --exclude-libs
PostGIS trac at osgeo.org
Mon Jan 4 02:33:16 PST 2016
  Reporter:  petere                 |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 2.2.1
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 It seems to be never adding --exclude-libs at link time, even if it's
 found to be available at configure time. This is the link line I see (make
 V=1):
 libtool: link: gcc -shared  -fPIC -DPIC  .libs/stringbuffer.o
 .libs/bytebuffer.o .libs/measures.o .libs/measures3d.o .libs/box2d.o
 .libs/ptarray.o .libs/lwgeom_api.o .libs/lwgeom.o .libs/lwpoint.o
 .libs/lwline.o .libs/lwpoly.o .libs/lwtriangle.o .libs/lwmpoint.o
 .libs/lwmline.o .libs/lwmpoly.o .libs/lwboundingcircle.o
 .libs/lwcollection.o .libs/lwcircstring.o .libs/lwcompound.o
 .libs/lwcurvepoly.o .libs/lwmcurve.o .libs/lwmsurface.o .libs/lwpsurface.o
 .libs/lwtin.o .libs/lwout_wkb.o .libs/lwin_geojson.o .libs/lwin_wkb.o
 .libs/lwin_twkb.o .libs/lwiterator.o .libs/lwout_wkt.o .libs/lwout_twkb.o
 .libs/lwin_wkt_parse.o .libs/lwin_wkt_lex.o .libs/lwin_wkt.o
 .libs/lwin_encoded_polyline.o .libs/lwutil.o .libs/lwhomogenize.o
 .libs/lwalgorithm.o .libs/lwstroke.o .libs/lwlinearreferencing.o
 .libs/lwprint.o .libs/g_box.o .libs/g_serialized.o .libs/g_util.o
 .libs/lwgeodetic.o .libs/lwgeodetic_tree.o .libs/lwtree.o
 .libs/lwout_gml.o .libs/lwout_kml.o .libs/lwout_geojson.o
 .libs/lwout_svg.o .libs/lwout_x3d.o .libs/lwout_encoded_polyline.o
 .libs/lwgeom_debug.o .libs/lwgeom_geos.o .libs/lwgeom_geos_clean.o
 .libs/lwgeom_geos_cluster.o .libs/lwgeom_geos_node.o
 .libs/lwgeom_geos_split.o .libs/lwgeom_topo.o .libs/lwgeom_transform.o
 .libs/lwunionfind.o .libs/effectivearea.o .libs/varint.o
 .libs/lwgeom_sfcgal.o .libs/lwspheroid.o   -L/usr/local/lib
 /usr/local/lib/libgeos_c.so /usr/lib/libproj.so
 /usr/local/lib/libjson-c.so /usr/local/lib/libSFCGAL.so    -Wl,-soname
 -Wl,liblwgeom-2.3.so.0 -o .libs/liblwgeom-2.3.so.0.0.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3415#comment:4>
