[postgis-tickets] [PostGIS] #3415: fails to build on OS X because of --exclude-libs
PostGIS trac at osgeo.org
Fri Jan 1 20:56:52 PST 2016
  Reporter:  petere                 |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 2.2.1
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by robe):
 I made the change for trunk and my compile and make check locally still
 work.  Did I make the right change.  If it looks right, I'll backport to
 2.2 and close this out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3415#comment:3>
