[postgis-tickets] [PostGIS] #3401: ST_ModEdgeSplit makes topology invalid
PostGIS trac at osgeo.org
Tue Jan 5 03:00:06 PST 2016
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.2.1
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:  32bit
Comment (by nicklas):
 strk
 Quite long time ago there was some issue, and if I recall right it was
 about st_split, that was caused by the way the distance functions work.
 Because distance functions use the same algorithms as st_closestpoint it
 calculates a point on a line that is truncated to double precision. Then
 the distance is calculated to that point.
 That approach can give a slightly different distance than calculating the
 distance directly and truncating the distance itself to double precision.
 Can this be the same issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3401#comment:13>
