[postgis-tickets] [PostGIS] #3401: ST_ModEdgeSplit makes topology invalid
trac at osgeo.org
Tue Jan 5 03:17:50 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.1
Component: topology | Version: trunk
Resolution: | Keywords: 32bit
Comment (by strk):
Here, test with only ST_Split:
=# with inp as ( SELECT 'LINESTRING(-180 0,0 0)'::geometry a, 'POINT(-20
0)'::geometry b ), op as ( select a,b,st_split(a,b) s from inp ), dumped
as ( select a,b,(st_dumppoints(s)).* from op ) select path,
st_astext(geom) endpoint, st_astext(b) split, st_equals(geom,b),
st_contains(a,b) from dumped;
path | endpoint | split | st_equals | st_contains
{1,1} | POINT(-180 0) | POINT(-20 0) | f | t
{1,2} | POINT(-20 0) | POINT(-20 0) | f | t
{2,1} | POINT(-20 0) | POINT(-20 0) | f | t
{2,2} | POINT(0 0) | POINT(-20 0) | f | t
(4 rows)
None of the endpoints of the split output equal the split point, although
the split point is contained in the originally splitted line...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3401#comment:14>
