[postgis-tickets] r14578 - Quote words with underscores in them
Sandro Santilli
strk at keybit.net
Wed Jan 6 09:22:12 PST 2016
Author: strk
Date: 2016-01-06 09:22:12 -0800 (Wed, 06 Jan 2016)
New Revision: 14578
web/_content/posts/2016/01-06_postgis-2.2.1.html
Or they are taken as a sign of emphasized text...
Modified: web/_content/posts/2016/01-06_postgis-2.2.1.html
--- web/_content/posts/2016/01-06_postgis-2.2.1.html 2016-01-06 15:16:26 UTC (rev 14577)
+++ web/_content/posts/2016/01-06_postgis-2.2.1.html 2016-01-06 17:22:12 UTC (rev 14578)
@@ -14,9 +14,9 @@
* #2232, avoid accumulated error in SVG rounding
* #3321, Fix performance regression in topology loading
* #3329, Fix robustness regression in TopoGeo_addPoint
- * #3349, Fix installation path of postgis_topology scripts
- * #3351, set endnodes isolation on ST_RemoveIsoEdge
- (and lwt_RemIsoEdge)
+ * #3349, Fix installation path of `postgis_topology` scripts
+ * #3351, set endnodes isolation on `ST_RemoveIsoEdge`
+ (and `lwt_RemIsoEdge`)
* #3355, geography `ST_Segmentize` has geometry bbox
* #3359, Fix toTopoGeom loss of low-id primitives from
TopoGeometry definition
@@ -25,13 +25,13 @@
* #3378, Fix handling of hierarchical TopoGeometries
in presence of multiple topologies
* #3380, #3402, Decimate lines on topology load
- * #3388, #3410, Fix missing end-points in ST_Removepoints
- * #3389, Buffer overflow in lwgeom_to_geojson
+ * #3388, #3410, Fix missing end-points in `ST_Removepoints`
+ * #3389, Buffer overflow in `lwgeom_to_geojson`
* #3390, Compilation under Alpine Linux 3.2
gives an error when compiling the postgis and `postgis_topology` extension
* #3393, ST_Area NaN for some polygons
- * #3401, Improve ST_Split robustness on 32bit systems
- * #3404, ST_ClusterWithin crashes backend
+ * #3401, Improve `ST_Split` robustness on 32bit systems
+ * #3404, `ST_ClusterWithin` crashes backend
* #3407, Fix crash on splitting a face or an edge
defining multiple TopoGeometry objects
* #3411, Clustering functions not using spatial index
