[postgis-tickets] r14589 - #3422,	double tests not passing on all architectures
    Paul Ramsey
    pramsey at cleverelephant.ca
    Mon Jan 11 06:29:58 PST 2016
Author: pramsey
Date: 2016-01-11 06:29:57 -0800 (Mon, 11 Jan 2016)
New Revision: 14589
   branches/2.2/liblwgeom/cunit/cu_tester.h
Modified: branches/2.2/liblwgeom/cunit/cu_tester.h
--- branches/2.2/liblwgeom/cunit/cu_tester.h	2016-01-11 13:53:00 UTC (rev 14588)
+++ branches/2.2/liblwgeom/cunit/cu_tester.h	2016-01-11 14:29:57 UTC (rev 14589)
@@ -23,10 +23,11 @@
 /* Our internal callback to register Suites with the main tester */
 typedef void (*PG_SuiteSetup)(void);
+#define ASSERT_DOUBLE_EQUAL_TOLERANCE 10e-8
 #define ASSERT_DOUBLE_EQUAL(o,e) do { \
-  if ( o != e ) \
+  if ( fabs((double)o-(double)e) > ASSERT_DOUBLE_EQUAL_TOLERANCE ) \
     fprintf(stderr, "[%s:%d]\n Expected: %g\n Obtained: %g\n", __FILE__, __LINE__, (double)(e), (o)); \
-  CU_ASSERT_EQUAL(o,(double)e); \
+  CU_ASSERT_DOUBLE_EQUAL((double)o,(double)e,ASSERT_DOUBLE_EQUAL_TOLERANCE); \
 } while (0);
 #define ASSERT_INT_EQUAL(o,e) do { \
