[postgis-tickets] [PostGIS] #3113: Add curve support to ST_Simplify
PostGIS trac at osgeo.org
Mon Jan 11 05:57:56 PST 2016
  Reporter:  aaime        |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.1.9
 Component:  postgis      |    Version:  2.1.x
Resolution:               |   Keywords:
Comment (by pramsey):
 OK, two cases here: the tolerance value is smaller than the size of most
 arcs, in which case just simplifying the linear bits might make sense, and
 linearizing the arcs first would be a Bad Idea. Second case, the tolerance
 value is much bigger than the arcs, so they should get wiped away and
 replaced... by what? Here linearizing at least forces a common logic onto
 the whole problem. Trying to reason about DP and arcs doesn't work so
 good, since DP assumes you can fit the inputs into a linear sleeve.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3113#comment:4>
