[postgis-tickets] [PostGIS] #3054: 9.0 build: passing argument 8 of ‘DefineCustomStringVariable’ from incompatible pointer type
trac at osgeo.org
Mon Jan 11 05:54:01 PST 2016
Reporter: strk | Owner: colivier
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
Anyone using this version combination and backend switching should have
found back-end switching didn't work, and we haven't seen that bug report,
so I assume nobody is. Nonetheless, I patched it up in r14588, so it
should actually work, in case anyone tries it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3054#comment:5>
