[postgis-tickets] r14588 - #3054, build warning on GUC change for PgSQL 9.0
Paul Ramsey pramsey at cleverelephant.ca
Mon Jan 11 05:53:00 PST 2016
Author: pramsey
Date: 2016-01-11 05:53:00 -0800 (Mon, 11 Jan 2016)
New Revision: 14588
   branches/2.1/postgis/lwgeom_backend_api.c
Modified: branches/2.1/postgis/lwgeom_backend_api.c
--- branches/2.1/postgis/lwgeom_backend_api.c	2016-01-11 08:58:30 UTC (rev 14587)
+++ branches/2.1/postgis/lwgeom_backend_api.c	2016-01-11 13:53:00 UTC (rev 14588)
@@ -79,21 +79,42 @@
 char* lwgeom_backend_name;
 struct lwgeom_backend_definition* lwgeom_backend = &lwgeom_backends[0];
+#if POSTGIS_PGSQL_VERSION >= 91
 static void lwgeom_backend_switch( const char* newvalue, void* extra )
-    int i;
+	int i;
-    if (!newvalue) { return; }
+	if (!newvalue) { return; }
-    for ( i = 0; i < LWGEOM_NUM_BACKENDS; ++i ) {
-	if ( !strcmp(lwgeom_backends[i].name, newvalue) ) {
-	    lwgeom_backend = &lwgeom_backends[i];
-	    return;
+	for ( i = 0; i < LWGEOM_NUM_BACKENDS; ++i ) {
+		if ( !strcmp(lwgeom_backends[i].name, newvalue) ) {
+			lwgeom_backend = &lwgeom_backends[i];
+			return;
-    lwerror("Can't find %s geometry backend", newvalue );
+	lwerror("Can't find %s geometry backend", newvalue );
+#else
+static const char * lwgeom_backend_switch( const char* newvalue, bool doit, GucSource source )
+	int i;
+	if (!newvalue)
+		return NULL;
+	for (i = 0; i < LWGEOM_NUM_BACKENDS; ++i)
+		if (!strcmp(lwgeom_backends[i].name, newvalue))
+			return newvalue;
+	return NULL;
+#endif
 void lwgeom_init_backend()
     DefineCustomStringVariable( "postgis.backend", /* name */
