[postgis-tickets] [PostGIS] #3422: test_lwgeom_split fails on various architectures
PostGIS trac at osgeo.org
Mon Jan 11 11:48:22 PST 2016
  Reporter:  sebastic  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.2.2
 Component:  postgis   |    Version:  2.2.x
Resolution:  fixed     |   Keywords:
Changes (by sebastic):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 Are you sure it's completely unrelated?
 The test is for the same issue (#3401), I think the problem just got
 moved.
 As I don't have time to endlessly debate this, I'll close this issue again
 because `test_lwgeom_split` doesn't fail any more. I'll keep the tests
 disabled for the problematic architectures.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3422#comment:12>
