[postgis-tickets] [PostGIS] #3422: test_lwgeom_split fails on various architectures
trac at osgeo.org
Tue Jan 12 01:19:16 PST 2016
Reporter: sebastic | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.2
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
The tests _are_ related. Robustness issues in lwgeom_split were found to
be the cause for corrupting topology, so rather than hiding the failure in
the C library, we should keep it exposed and try to fix it instead.
The correct solution would be to keep the split point as a vertex, rather
than re-projecting it, when found to be already ON the segment.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3422#comment:13>
