[postgis-tickets] r14595 - Avoid any drift of cutter point on lines split
Sandro Santilli
strk at keybit.net
Wed Jan 13 03:35:15 PST 2016
Author: strk
Date: 2016-01-13 03:35:15 -0800 (Wed, 13 Jan 2016)
New Revision: 14595
branches/2.2/NEWS
branches/2.2/liblwgeom/cunit/cu_tester.h
branches/2.2/liblwgeom/lwgeom_geos_split.c
Should fix splitting operations on at least arm64, ppc64el and s390x.
See #3422 and #3401 (for 2.2 branch)
Also turn ASSERT_DOUBLE_EQUAL back to a tolerance-free check
(better use a different name for tolerance-aware check,
so caller can decide)
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-01-13 11:09:24 UTC (rev 14594)
+++ branches/2.2/NEWS 2016-01-13 11:35:15 UTC (rev 14595)
@@ -3,7 +3,8 @@
* Bug Fixes *
+ - #3422, Improve ST_Split robustness on standard precision double
+ systems (arm64, ppc64el, s390c, powerpc, ...)
PostGIS 2.2.1
2016/01/06
Modified: branches/2.2/liblwgeom/cunit/cu_tester.h
--- branches/2.2/liblwgeom/cunit/cu_tester.h 2016-01-13 11:09:24 UTC (rev 14594)
+++ branches/2.2/liblwgeom/cunit/cu_tester.h 2016-01-13 11:35:15 UTC (rev 14595)
@@ -23,11 +23,10 @@
/* Our internal callback to register Suites with the main tester */
typedef void (*PG_SuiteSetup)(void);
-#define ASSERT_DOUBLE_EQUAL_TOLERANCE 10e-8
#define ASSERT_DOUBLE_EQUAL(o,e) do { \
- if ( fabs((double)o-(double)e) > ASSERT_DOUBLE_EQUAL_TOLERANCE ) \
+ if ( o != e ) \
fprintf(stderr, "[%s:%d]\n Expected: %g\n Obtained: %g\n", __FILE__, __LINE__, (double)(e), (o)); \
- CU_ASSERT_DOUBLE_EQUAL((double)o,(double)e,ASSERT_DOUBLE_EQUAL_TOLERANCE); \
+ CU_ASSERT_EQUAL(o,(double)e); \
} while (0);
#define ASSERT_INT_EQUAL(o,e) do { \
Modified: branches/2.2/liblwgeom/lwgeom_geos_split.c
--- branches/2.2/liblwgeom/lwgeom_geos_split.c 2016-01-13 11:09:24 UTC (rev 14594)
+++ branches/2.2/liblwgeom/lwgeom_geos_split.c 2016-01-13 11:35:15 UTC (rev 14595)
@@ -258,6 +258,7 @@
mindist = dist;
seg=i;
+ if ( mindist == 0.0 ) break; /* can't be closer than ON line */
p1 = p2;
@@ -273,11 +274,18 @@
* We need to project the
- * point on the closest segment.
+ * point on the closest segment,
+ * to interpolate Z and M if needed
getPoint4d_p(ipa, seg, &p1);
getPoint4d_p(ipa, seg+1, &p2);
closest_point_on_segment(&pt, &p1, &p2, &pt_projected);
+ /* But X and Y we want the ones of the input point,
+ * as on some architectures the interpolation math moves the
+ * coordinates (see #3422)
+ pt_projected.x = pt.x;
+ pt_projected.y = pt.y;
LWDEBUGF(3, "Projected point:(%g %g), seg:%d, p1:(%g %g), p2:(%g %g)", pt_projected.x, pt_projected.y, seg, p1.x, p1.y, p2.x, p2.y);
