[postgis-tickets] [PostGIS] #3426: Patch to fix test_wkb_out_point failure on hppa & mips.
trac at osgeo.org
Wed Jan 13 04:49:10 PST 2016
Reporter: sebastic | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.2
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by gdt):
I think this change should be backed out as not clean enough, and instead
the code should start with a real NaN and convert to WKB to test.
I don't think it's reasonable to worry about vax (or other, even less
plausible, non-IEEE754 machines).
This change probably also fails to address a number of other big-endian
platforms, like sparc64 and BE arm variants.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3426#comment:5>
