[postgis-tickets] [PostGIS] #3428: Feature request: A function to convert a geometry's coordinates into a MultiPoint
trac at osgeo.org
Wed Jan 13 17:04:34 PST 2016
MultiPoint
Reporter: mwtoews | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Changes (by mwtoews):
* version: => 2.2.x
Comment:
The performance degrades with more geometries (e.g. 500 geometries, each
with 1000 points):
DROP TABLE IF EXISTS random_lines;
SELECT id, ST_MakeLine(array_agg(pt)) AS geom
INTO TEMP random_lines
FROM (
SELECT id, ST_MakePoint(random(), random()) pt
FROM generate_series(1, 500) id, generate_series(1, 1000)
) r
GROUP BY id;
-- Test 1
WITH rows AS (
SELECT ST_NPoints(ST_ToMultiPoint(geom)) FROM random_lines)
SELECT count(*) FROM rows;
-- Test 2
WITH rows AS (
SELECT ST_NPoints(geom) FROM random_lines)
With PostGIS 2.1 I'm comparing 500 ms vs. 30 ms.
(Where I really noticed this issue was with an older PostGIS 1.5 that my
work insists on using, where I'm comparing a painful 22021 ms vs. 30 ms,
which is dismal, but on an unsupported release.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3428#comment:3>
