[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
trac at osgeo.org
Fri Jan 15 00:08:40 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.2
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
One additional information: the 2.1.3 install is not fully clean, because
the scripts refer to postgis library with "2.1" and the installed "2.1" is
actually a 2.1.9dev:
POSTGIS="2.1.9dev r14472" GEOS="3.6.0dev-CAPI-1.10.0 r4138" PROJ="Rel.
4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.9.1" LIBJSON="UNKNOWN" (core procs from "2.1.3 r12547" need
upgrade) RASTER (raster procs from "2.1.3 r12547" need upgrade)
Anyway, I can also reproduce upgrading from 2.1.9dev, so it's not related.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:8>
