[postgis-tickets] [PostGIS] #3434: Creating topogeom errors when topogeom name includes CAPITAL LETTERS
trac at osgeo.org
Tue Jan 19 05:03:01 PST 2016
Reporter: LucasBr | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: topology | Version: 2.2.x
Keywords: |
I was getting an error when trying to create a topogeom with a name that
included capital letters. Shouldn't Postgresql be case insensitive? The
error occurs in the "toTopoGeom" function.
See reproducible example bellow
-- Testing case sensitivity
SELECT topology.DropTopology('test1');
SELECT topology.CreateTopology('test1',32719);
SELECT topology.addtopogeometrycolumn('test1',
'public','temp_geom_ac','tg_a','POLYGON');
UPDATE temp_geom_ac SET tg_a = toTopoGeom(geom_dump_utm,'test1', 1, 1) ;
-- ERROR: Spatial exception - geometry intersects edge 541
-- CONTEXT: PL/pgSQL function totopogeom(geometry,topogeometry,double
precision) line 111 at FOR over SELECT rows
-- PL/pgSQL function totopogeom(geometry,character varying,integer,double
precision) line 94 at assignment
-- Above, with tg_a in lower letters, it "works" (I mean the erros is
because of problems in the polygons, not calling the topogeom name)
SELECT topology.DropTopology('test2');
SELECT topology.CreateTopology('test2',32719);
SELECT topology.addtopogeometrycolumn('test2',
'public','temp_geom_ac','tg_B','POLYGON');
UPDATE temp_geom_ac SET tg_B = toTopoGeom(geom_dump_utm,'test2', 1, 1) ;
-- ERROR: column "tg_b" of relation "temp_geom_ac" does not exist
-- LINE 1: UPDATE temp_geom_ac SET tg_B = toTopoGeom(geom_dump_utm,'tes...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3434>
