[postgis-tickets] [PostGIS] #3441: [raster] Create out-db file using ST_AddBand
PostGIS trac at osgeo.org
Tue Jan 26 09:29:13 PST 2016
 Reporter:  gdrolet             |      Owner:  dustymugs
     Type:  enhancement         |     Status:  new
 Priority:  medium              |  Milestone:  PostGIS 2.3.0
Component:  raster              |    Version:  trunk
 Keywords:  ST_AddBand, out-db  |
 Following the examples in the manual, I wanted to create a new out-db file
 using ST_AddBand:
 SELECT ST_AddBand(
         ST_MakeEmptyRaster(10, 10, 0, 0, 50), 1,
         'E:\Temp\mytestraster.tif'::text, ARRAY[]::integer[]);
 Which returns with this error:
 ERROR:  RASTER_addBandOutDB: Could not open out-db file with GDAL
 ********** Error **********
 After checking that the permissions on the path are ok, I realized that
 the out-db file must already exist somewhere in the system for the query
 to work (or am I wrong?).
 I think it would be nice if we had the possibility to create a new raster
 file (registered as an out-db file in the database) using the query above
 or something similar.
 PostGIS version:
 POSTGIS="2.3.0dev r14604" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1,
 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
 LIBJSON="0.12" RASTER
 PostgreSQL 9.4 on Windows 7 Enterprise 64-bit (SP1)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3441>
