[postgis-tickets] [PostGIS] #3587: lwgeom_mindistance2d slows down topology loading
trac at osgeo.org
Wed Jul 6 00:56:39 PDT 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: topology | Version: 2.2.x
Resolution: | Keywords: performance
Comment (by strk):
Another great idea (for topology): DROP the distance computation.
Given that distance is only used to reduce the number of ST_Snap
operations, and that ST_Snap would be a no-op if no vertex is closer than
the given tolerated distance... we might as well just avoid to perform the
pre-flight check.
The testsuite is fine with that, which is a good sign!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3587#comment:33>
