[postgis-tickets] r15008 - Remove docker configuration,
Sandro Santilli
strk at kbt.io
Thu Jul 21 04:31:50 PDT 2016
Author: strk
Date: 2016-07-21 04:31:50 -0700 (Thu, 21 Jul 2016)
New Revision: 15008
Removed:
trunk/docker/build-test/Dockerfile.trisquel
trunk/docker/build-test/Makefile
Project moved to:
http://git.osgeo.org/gogs/postgis/postgis-docker
Deleted: trunk/docker/build-test/Dockerfile.trisquel
--- trunk/docker/build-test/Dockerfile.trisquel 2016-07-21 11:26:33 UTC (rev 15007)
+++ trunk/docker/build-test/Dockerfile.trisquel 2016-07-21 11:31:50 UTC (rev 15008)
@@ -1,8 +0,0 @@
-FROM kpengboy/trisquel
-RUN apt-get update -qq && apt-get install -y \
- postgresql-9.3 postgresql-server-dev-9.3 \
- build-essential autoconf libtool libcunit1-dev \
- xsltproc docbook-xsl docbook-mathml dblatex \
- libproj-dev libgdal-dev libgeos-dev libjson0-dev
-RUN service postgresql start && su -l postgres -c "createuser -s `whoami`"
Deleted: trunk/docker/build-test/Makefile
--- trunk/docker/build-test/Makefile 2016-07-21 11:26:33 UTC (rev 15007)
+++ trunk/docker/build-test/Makefile 2016-07-21 11:31:50 UTC (rev 15008)
@@ -1,13 +0,0 @@
-DOCKER=docker
-REGISTRY=docker.kbt.io
-NAME=$(REGISTRY)/postgis/build-test
-all: trisquel
-push: trisquel-push
-trisquel:
- $(DOCKER) build -t $(NAME):trisquel - < Dockerfile.trisquel
-trisquel-push:
- $(DOCKER) push $(NAME):trisquel
