[postgis-tickets] [PostGIS] #3574: Korean Manual AutoUpdate Stopped
PostGIS trac at osgeo.org
Mon Jul 25 02:43:03 PDT 2016
  Reporter:  ruvyn          |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 2.3.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:  PostGIS 2.3.0dev Manual
Comment (by strk):
 Ruvyn: It takes no authority to generate the HTML pages locally. The
 "make" commands showed above should let you do that, so you can check if
 your translations work.
 Anyway, after a "make pull-tx" the generation still fails:
 /usr/bin/xsltproc --novalid ./xsl/postgis_aggs_mm.xml.xsl postgis-out.xml
 > postgis_aggs_mm.xml
 reference_accessor.xml:2589: parser error : Opening and ending tag
 mismatch: varname line 2588 and refpurpose
 (면)을 반환합니다. 그 외의 경우 NULL을 반환합니다.</refpurpose
 reference_accessor.xml:2590: parser error : Opening and ending tag
 mismatch: varname line 2587 and refnamediv
           </refnamediv>
 reference_accessor.xml:2624: parser error : Opening and ending tag
 mismatch: varname line 2623 and para
 을 반환합니다. ST_GeometryN을 이용하는 편이 더 빠릅니다.</para
 reference_accessor.xml:2645: parser error : Opening and ending tag
 mismatch: varname line 2622 and refsection
           </refsection>
 reference_accessor.xml:2675: parser error : Opening and ending tag
 mismatch: varname line 2621 and refentry
         </refentry>
 reference_accessor.xml:3962: parser error : Opening and ending tag
 mismatch: varname line 2620 and sect1
   </sect1>
 reference_accessor.xml:3963: parser error : Premature end of data in tag
 para line 2619
 refsection line 2615
 varname line 2586
 varname line 2585
 refpurpose line 2584
 refnamediv line 2580
 refentry line 2579
 sect1 line 3
 reference.xml:13: parser error : Failure to process entity
 reference_accessor
 ference_guc; &reference_management; &reference_constructor;
 &reference_accessor;
 reference.xml:13: parser error : Entity 'reference_accessor' not defined
 reference_editor.xml:68: parser error : Opening and ending tag mismatch:
 position line 67 and para
 생략하거나, 추가 작업에 대해 -1로 설정할 수 있습니다.</para
 There are more errors like the above, so I'd recommend getting a clone of
 the PostGIS git repository (https://git.osgeo.org/gogs/postgis/postgis)
 and try the generation yourself until it's fixed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3574#comment:3>
