[postgis-tickets] [PostGIS] #3496: Make postgis non-relocateable and schema qualify at least core functions
trac at osgeo.org
Fri Jul 29 02:13:29 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
Sorry, figured (it's all explained in the summary).
So basically via extension-install you decide the installation schema at
"CREATE EXTENSION" time, and the same basically happens on non-extension-
install (things are installed in the first schema of the search_path).
The difference between extension and non-extension installs is that
extension-install has internal calls all fully-qualified to the schema
decided at installation time, while non-extension install do not.
In turn, the above means that upgrade may still be broken for non-
extension installs, right ?
I'm a bit afraid of this difference between extension and non-extension
install.
Moving to hard-coded destination schema (decided at build time) should
remove the difference, and we'd have all internal linking schema-
qualified.
Or, we should provide a postgis enabler-script to replace the manual load
of the .sql files and provide the ability to specify target schema at that
time. Would that be a too big of a change for non-extension installs ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3496#comment:8>
