[postgis-tickets] [PostGIS] #3602: perl as found by configure is not used in tiger extension, postgis_sfcgal, address_standardizer
PostGIS trac at osgeo.org
Sat Jul 30 09:56:53 PDT 2016
  Reporter:  gdt                    |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.2.3
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 In [changeset:"15026" 15026]:
 #!CommitTicketReference repository="" revision="15026"
 perl as found by configure is not used in tiger, sfcgal, or
 address_standardizer extensions
 references #3602 for PostGIS 2.3 (trunk)
 tiger_data not being backed up and add upgrade test
 references #3515 for PostGIS 2.3 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3602#comment:3>
