[postgis-tickets] [PostGIS] #3496: Make postgis non-relocateable and schema qualify at least core functions
PostGIS trac at osgeo.org
Sun Jul 31 22:13:31 PDT 2016
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 Just about done schema qualifying all calls in raster.  I probably missed
 some spots.  I took out the add search_path to raster function from
 postgis extension include since not needed anymore.
 However I had to change some tests (the ones that are supposed to error,
 errored in different location if installed via extension because of the
 extra characters introduced by the schema.  So get something like error in
 Character 68 instead of Character 62.  Very annoying.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3496#comment:10>
