[postgis-tickets] [PostGIS] #3541: Automatically convert Polygon to CurvePolygon when required
trac at osgeo.org
Mon May 2 02:45:45 PDT 2016
Reporter: mkuhn | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: 2.2.x
Keywords: curve, curvepolygon, conversion |
When trying to insert a regular Polygon into a table with CurvePolygon
type the operation fails with an error
ERROR: Geometry type (Polygon) does not match column type (CurvePolygon)
As far as I understand, the conversion from Polygon to CurvePolygon is
lossless. Could this conversion be done implicitly? I cannot imagine a
case where a user will take another action than adding an explicit
conversion step from Polygon to CurvePolygon after seeing this message, so
it might as well just happen implicitly.
The fact that at the moment there is no way to convert from Polygon to
CurvePolygon apart from going through WKT (see #1291) makes this issue
even more painful.
The same applies to LineString > CircularString and conceptually also to
MultiCurve (untested).
> SELECT ST_GeomFromText('LINESTRING(75.15 29.53,77 29,77.6
29.5)')::geometry('CircularString');
ERROR: Geometry type (LineString) does not match column type
(CircularString)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3541>
