[postgis-tickets] [PostGIS] #3541: Automatically convert Polygon to CurvePolygon when required
trac at osgeo.org
Mon May 2 23:51:02 PDT 2016
Reporter: mkuhn | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: 2.2.x
Resolution: wontfix | Keywords: curve, curvepolygon, conversion
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
LINESTRING with 3 points would result in a circularlinestring implicitly
only if you assume that you want the middle to be a control point. This
is a big jump in assumption to me. As I would expect a LINESTRING that
forms into a curve to be a curve.
So I don't feel this warrants blind conversion option.
Even if it did, I don't think its possible the way we have PostGIS
constructed to morph from one subtype geometry to another. Note we only
have casts from geometry, geography, box, box2d, box3d, raster but those
are all separate types, not subtypes of the same type.
pramsey or strk can correct me if my assumptions are wrong here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3541#comment:1>
