[postgis-tickets] [PostGIS] #3470: ST_Polygonize doesn't accept NULL geometries
PostGIS trac at osgeo.org
Tue May 3 17:57:43 PDT 2016
  Reporter:  kohnivo  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  ST_Polygonize, NULL value
Changes (by dbaston):
 * milestone:   => PostGIS 2.2.3
Comment:
 I've fixed this in trunk at r14882.
 Should this be backported to 2.2?  It ''does'' change behavior, but it
 looks like the old behavior involves a dirty read, based on the error
 messages kohnivo is reporting, as well as what I'm seeing:
 postgres=# SELECT '#3470',
 ST_Polygonize(ARRAY[NULL::geometry]::geometry[]);
 ERROR:  Unknown geometry type: 64 - Invalid type
 postgres=# SELECT '#3470', ST_Polygonize(ARRAY['LINESTRING (0 0, 1 1)',
 ERROR:  Unknown geometry type: 17337632 - Invalid type
 NULL]::geometry[]);
 ERROR:  Unknown geometry type: 0 - Unknown
 Porting it back to 2.1 is trickier, as the fix involves switching to
 simplified code introduced in 2.2.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3470#comment:1>
