[postgis-tickets] [PostGIS] #3470: ST_Polygonize doesn't accept NULL geometries
trac at osgeo.org
Wed May 4 03:01:10 PDT 2016
Reporter: kohnivo | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: ST_Polygonize, NULL value
Comment (by strk):
For sure a dirty read fix needs backporting.
But before backporting, should we also have a test with an array
containing both null and not-null geometries ? Ideally we'd have the same
behavior as ST_Collect (to be checked). There are two possible handling:
the null elements are just skipped OR the whole array is considered null
(and thus the output is also null)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3470#comment:2>
