[postgis-tickets] r14884 - #3470, ST_Polygonize doesn't accept NULL geometries
Daniel Baston dbaston at gmail.com
Wed May 4 15:02:48 PDT 2016
Author: dbaston
Date: 2016-05-04 15:02:48 -0700 (Wed, 04 May 2016)
New Revision: 14884
   branches/2.2/postgis/lwgeom_accum.c
   branches/2.2/postgis/lwgeom_geos.c
   branches/2.2/regress/tickets.sql
   branches/2.2/regress/tickets_expected
Modified: branches/2.2/postgis/lwgeom_accum.c
--- branches/2.2/postgis/lwgeom_accum.c	2016-05-04 21:48:46 UTC (rev 14883)
+++ branches/2.2/postgis/lwgeom_accum.c	2016-05-04 22:02:48 UTC (rev 14884)
@@ -275,7 +275,9 @@
 	p = (pgis_abs*) PG_GETARG_POINTER(0);
 	geometry_array = pgis_accum_finalfn(p, CurrentMemoryContext, fcinfo);
-	result = DirectFunctionCall1( polygonize_garray, geometry_array );
+	result = PGISDirectFunctionCall1( polygonize_garray, geometry_array );
+	if (!result)
+		PG_RETURN_NULL();
 	PG_RETURN_DATUM(result);
Modified: branches/2.2/postgis/lwgeom_geos.c
--- branches/2.2/postgis/lwgeom_geos.c	2016-05-04 21:48:46 UTC (rev 14883)
+++ branches/2.2/postgis/lwgeom_geos.c	2016-05-04 22:02:48 UTC (rev 14884)
@@ -3371,7 +3371,6 @@
 PG_FUNCTION_INFO_V1(polygonize_garray);
 Datum polygonize_garray(PG_FUNCTION_ARGS)
-	Datum datum;
 	ArrayType *array;
 	int is3d = 0;
 	uint32 nelems, i;
@@ -3379,7 +3378,6 @@
 	GEOSGeometry *geos_result;
 	const GEOSGeometry **vgeoms;
 	int srid=SRID_UNKNOWN;
-	size_t offset;
 #if POSTGIS_DEBUG_LEVEL >= 3
 	static int call=1;
 #endif
@@ -3388,48 +3386,22 @@
 	call++;
 #endif
-	datum = PG_GETARG_DATUM(0);
+	if (PG_ARGISNULL(0))
+		PG_RETURN_NULL();
-	/* Null array, null geometry (should be empty?) */
-	if ( (Pointer *)datum == NULL ) PG_RETURN_NULL();
+	array = PG_GETARG_ARRAYTYPE_P(0);
+	nelems = array_nelems_not_null(array);
-	array = DatumGetArrayTypeP(datum);
+	if (nelems == 0)
+		PG_RETURN_NULL();
-	nelems = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
+	POSTGIS_DEBUGF(3, "polygonize_garray: number of non-null elements: %d", nelems);
-	POSTGIS_DEBUGF(3, "polygonize_garray: number of elements: %d", nelems);
-	if ( nelems == 0 ) PG_RETURN_NULL();
 	/* Ok, we really need geos now ;) */
 	initGEOS(lwpgnotice, lwgeom_geos_error);
-	vgeoms = palloc(sizeof(GEOSGeometry *)*nelems);
-	offset = 0;
-	for (i=0; i<nelems; i++)
-		GEOSGeometry* g;
-		GSERIALIZED *geom = (GSERIALIZED *)(ARR_DATA_PTR(array)+offset);
-		offset += INTALIGN(VARSIZE(geom));
-		if ( ! is3d ) is3d = gserialized_has_z(geom);
+	vgeoms = (const GEOSGeometry**) ARRAY2GEOS(array, nelems, &is3d, &srid);
-		g = (GEOSGeometry *)POSTGIS2GEOS(geom);
-		if ( 0 == g )   /* exception thrown at construction */
-			HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
-			PG_RETURN_NULL();
-		vgeoms[i] = g;
-		if ( ! i )
-			srid = gserialized_get_srid(geom);
-		else
-			error_if_srid_mismatch(srid, gserialized_get_srid(geom));
 	POSTGIS_DEBUG(3, "polygonize_garray: invoking GEOSpolygonize");
 	geos_result = GEOSPolygonize(vgeoms, nelems);
@@ -3450,10 +3422,7 @@
 		PG_RETURN_NULL(); /*never get here */
-	/*compressType(result); */
 	PG_RETURN_POINTER(result);
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql	2016-05-04 21:48:46 UTC (rev 14883)
+++ branches/2.2/regress/tickets.sql	2016-05-04 22:02:48 UTC (rev 14884)
@@ -943,5 +943,9 @@
 UNION ALL
 SELECT '#3437e' AS t, count(*) FROM mp INNER JOIN p ON ST_Within(p.geom, mp.geom);
+-- #3470
+SELECT '#3470', ST_Polygonize(ARRAY[NULL]::geometry[]) IS NULL;
+SELECT '#3470b', ST_Area(ST_Polygonize(ARRAY[NULL, 'LINESTRING (0 0, 10 0, 10 10)', NULL, 'LINESTRING (0 0, 10 10)', NULL]::geometry[]));
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected	2016-05-04 21:48:46 UTC (rev 14883)
+++ branches/2.2/regress/tickets_expected	2016-05-04 22:02:48 UTC (rev 14884)
@@ -289,3 +289,5 @@
 #3437c|5
 #3437d|5
 #3437e|5
+#3470|t
+#3470b|50
