[postgis-tickets] r14883 - Add additional test to document ST_Polygonize behavior with nulls
Daniel Baston
dbaston at gmail.com
Wed May 4 14:48:47 PDT 2016
Author: dbaston
Date: 2016-05-04 14:48:46 -0700 (Wed, 04 May 2016)
New Revision: 14883
trunk/regress/tickets.sql
trunk/regress/tickets_expected
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql 2016-05-04 00:56:52 UTC (rev 14882)
+++ trunk/regress/tickets.sql 2016-05-04 21:48:46 UTC (rev 14883)
@@ -964,6 +964,7 @@
-- #3470
SELECT '#3470', ST_Polygonize(ARRAY[NULL]::geometry[]) IS NULL;
+SELECT '#3470b', ST_Area(ST_Polygonize(ARRAY[NULL, 'LINESTRING (0 0, 10 0, 10 10)', NULL, 'LINESTRING (0 0, 10 10)', NULL]::geometry[]));
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected 2016-05-04 00:56:52 UTC (rev 14882)
+++ trunk/regress/tickets_expected 2016-05-04 21:48:46 UTC (rev 14883)
@@ -293,3 +293,4 @@
#3437d|5
#3437e|5
#3470|t
+#3470b|50
