[postgis-tickets] [PostGIS] #3546: github mirror is down
trac at osgeo.org
Thu May 12 03:10:58 PDT 2016
Reporter: dbaston | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone:
Component: management | Version:
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* version: 2.2.x =>
* resolution: => fixed
* milestone: PostGIS 2.2.3 =>
Comment:
Should be fixed again now. The problem was that the mirroring service was
forced to use HTTPS but the version of "wget" on the SVN server was too
old to support virtual-host based SSL
(https://en.wikipedia.org/wiki/Server_Name_Indication) so the server
returned a random certificate which happened not to match the requested
host.
It was fixed by using "curl" instead of "wget", which did not suffer from
this problem.
See https://git.osgeo.org/gogs/postgis/postgis-svn-
hooks/commit/06380c745702d25d5f1dc47375a511542aa4b152
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3546#comment:2>
