[postgis-tickets] [PostGIS] #3513: topology tests failing for PostgreSQL 9.6
trac at osgeo.org
Thu May 5 16:09:05 PDT 2016
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.3.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay since it's still not working. I took 9.6 out of the matrix testing,
that way trunk won't show as a failure, but moved it to a post build check
- so it is still tested.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3513#comment:8>
