[postgis-tickets] [PostGIS] #2362: Support building with CMake
trac at osgeo.org
Thu May 5 17:31:13 PDT 2016
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I think GEOS detection needs some work. It doesn't like my GEOS 3.5.0 yet
it does find it.
CMake Error at
C:/ming64gcc48/cmake-3.5.2-win32-x86/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:148
(message):
Could NOT find GEOS: Found unsuitable version "", but required is at
least
"3.4" (found
C:/ming64gcc48/projects/geos/rel-3.5.0w64gcc48/lib/libgeos_c.dll.a)
Call Stack (most recent call first):
C:/ming64gcc48/cmake-3.5.2-win32-x86/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:386
(_FPHSA_FAILURE_MESSAGE)
cmake/FindGEOS.cmake:162 (find_package_handle_standard_args)
cmake/FindAnyProject.cmake:82 (find_package)
CMakeLists.txt:154 (find_anyproject)
I tried swithching to my GEOS 3.4.2 build and it didn't like that either:
PATH AFTER:
/projects/gtkw64gcc48/bin:/projects/geos/rel-3.4.2w64gcc48/bin:/projects/gdal/rel-2.1.0w64gcc48/bin:/projects
/rel-libiconv-1.13.1w64gcc48/lib:/projects/rel-
libiconv-1.13.1w64gcc48/include:/projects/rel-lib
Already up-to-date.
-- ←[1;33mpostgis version 2.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1←[m
-- ←[1;4;34mConfiguring PostGIS:←[0m
-- Found PostgreSQL:
C:/ming64gcc48/projects/postgresql/rel/pg9.6w64gcc48/lib/libpq.dll (found
suitable version "9.6devel", minimum required is "9.1")
-- Performing Test ICONV_HAVE_WERROR
-- Performing Test ICONV_HAVE_WERROR - Success
-- Performing Test ICONV_SECOND_ARGUMENT_IS_CONST
-- Performing Test ICONV_SECOND_ARGUMENT_IS_CONST - Failed
-- Found Iconv: C:/ming64gcc48/projects/rel-
libiconv-1.13.1w64gcc48/lib/libiconv.dll.a
-- Found PROJ4:
C:/ming64gcc48/projects/proj/rel-4.9.1w64gcc48/lib/libproj.dll.a (found
suitable version "4.9.1", minimum required is "4.6")
CMake Error at
(message):
least
"3.4" (found
C:/ming64gcc48/projects/geos/rel-3.4.2w64gcc48/lib/libgeos_c.dll.a)
-- Configuring incomplete, errors occurred!
See also
"C:/ming64gcc48/projects/postgis/branches/2.3cmake/CMakeFiles/CMakeOutput.log".
See also
"C:/ming64gcc48/projects/postgis/branches/2.3cmake/CMakeFiles/CMakeError.log".
I'm building under mingw64-w64 and I built GEOS with CMake. The others it
detected correctly I built using standard autotools chain.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2362#comment:6>
