[postgis-tickets] r14889 - Simplify GML test for P1/P2 to use a single ORDER BY
Sandro Santilli
strk at keybit.net
Wed May 11 02:53:39 PDT 2016
Author: strk
Date: 2016-05-11 02:53:39 -0700 (Wed, 11 May 2016)
New Revision: 14889
trunk/topology/test/regress/gml.sql
trunk/topology/test/regress/gml_expected
This is yet another attempt to fix #3513
Modified: trunk/topology/test/regress/gml.sql
--- trunk/topology/test/regress/gml.sql 2016-05-11 09:26:31 UTC (rev 14888)
+++ trunk/topology/test/regress/gml.sql 2016-05-11 09:53:39 UTC (rev 14889)
@@ -177,12 +177,9 @@
-- E13-> (N9),(N10) # N9 visited by P1-visited.E20, N10 above
SELECT feature_name||'-visited', topology.AsGML(feature,
- '', 15, 2, 'visited'::regclass) FROM
- SELECT * FROM features.land_parcels
+ '', 15, 2, 'visited'::regclass) FROM features.land_parcels
WHERE feature_name IN ('P1', 'P2')
- ORDER BY feature_name ASC
- ) foo ORDER BY feature_name DESC;
+ ORDER BY feature_name;
-- F3F4 visits (F3),(F4)
Modified: trunk/topology/test/regress/gml_expected
--- trunk/topology/test/regress/gml_expected 2016-05-11 09:26:31 UTC (rev 14888)
+++ trunk/topology/test/regress/gml_expected 2016-05-11 09:53:39 UTC (rev 14889)
@@ -55,8 +55,8 @@
S3-visited|<TopoPoint><directedNode xlink:href="#N6" /></TopoPoint>
R1-visited|<TopoCurve><directedEdge><Edge id="E9"><directedNode orientation="-"><Node id="N15"/></directedNode><directedNode xlink:href="#N14" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 21 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-"><Edge id="E10"><directedNode orientation="-"><Node id="N13"/></directedNode><directedNode xlink:href="#N14" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 21 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
N1N6N14-visited|<TopoPoint><directedNode><Node id="N1"><pointProperty><Point srsName="EPSG:4326"><pos>8 30</pos></Point></pointProperty></Node></directedNode><directedNode xlink:href="#N6" /><directedNode xlink:href="#N14" /></TopoPoint>
+P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge orientation="-"><Edge id="E6"><directedNode orientation="-"><Node id="N16"/></directedNode><directedNode><Node id="N17"/></directedNode><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 22 21 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="E19"><directedNode orientation="-" xlink:href="#N14" /><directedNode xlink:href="#N17" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>21 14 21 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge xlink:href="#E9" /><directedEdge orientation="-"><Edge id="E21"><directedNode orientation="-" xlink:href="#N15" /><directedNode xlink:href="#N16" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 9 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></di
rectedEdge></Face></directedFace><directedFace><Face id="F6"><directedEdge orientation="-" xlink:href="#E9" /><directedEdge><Edge id="E20"><directedNode orientation="-"><Node id="N9"/></directedNode><directedNode xlink:href="#N14" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 21 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="E12"><directedNode orientation="-"><Node id="N8"/></directedNode><directedNode xlink:href="#N9" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 21 6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-"><Edge id="E22"><directedNode orientation="-" xlink:href="#N8" /><directedNode xlink:href="#N15" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 9 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></
directedEdge></Face></directedFace></TopoSurface>
P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge orientation="-"><Edge id="E7"><directedNode orientation="-" xlink:href="#N17" /><directedNode><Node id="N18"/></directedNode><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>21 22 35 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="E17"><directedNode orientation="-" xlink:href="#N13" /><directedNode xlink:href="#N18" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 35 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-" xlink:href="#E10" /><directedEdge orientation="-" xlink:href="#E19" /></Face></directedFace><directedFace><Face id="F7"><directedEdge xlink:href="#E10" /><directedEdge><Edge id="E18"><directedNode orientation="-"><Node id="N10"/></directedNode><directedNode xlink:href="#N13" /><curveProperty><Curve srsName
="EPSG:4326"><segments><LineStringSegment><posList>35 6 35 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="E13"><directedNode orientation="-" xlink:href="#N9" /><directedNode xlink:href="#N10" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 35 6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-" xlink:href="#E20" /></Face></directedFace></TopoSurface>
-P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge orientation="-"><Edge id="E6"><directedNode orientation="-"><Node id="N16"/></directedNode><directedNode><Node id="N17"/></directedNode><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 22 21 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="E19"><directedNode orientation="-" xlink:href="#N14" /><directedNode xlink:href="#N17" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>21 14 21 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge xlink:href="#E9" /><directedEdge orientation="-"><Edge id="E21"><directedNode orientation="-" xlink:href="#N15" /><directedNode xlink:href="#N16" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 9 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></di
F3F4-visited|<TopoSurface><directedFace xlink:href="#F3" /><directedFace xlink:href="#F4" /></TopoSurface>
E7E8-visited|<TopoCurve><directedEdge xlink:href="#E7" /><directedEdge><Edge id="E8"><directedNode orientation="-" xlink:href="#N18" /><directedNode><Node id="N19"/></directedNode><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>35 22 47 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
P3-visited-idprefix|<TopoSurface><directedFace><Face id="cd-F5"><directedEdge orientation="-" xlink:href="#cd-E8" /><directedEdge><Edge id="cd-E15"><directedNode orientation="-"><Node id="cd-N12"/></directedNode><directedNode xlink:href="#cd-N19" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>47 14 47 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="cd-E11"><directedNode orientation="-" xlink:href="#cd-N13" /><directedNode xlink:href="#cd-N12" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 47 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-" xlink:href="#cd-E17" /></Face></directedFace><directedFace><Face id="cd-F8"><directedEdge orientation="-" xlink:href="#cd-E11" /><directedEdge><Edge id="cd-E16"><directedNode orientation="-"><Node id="cd-N11"/></directedNode><directedNode x
link:href="#cd-N12" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>47 6 47 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge id="cd-E14"><directedNode orientation="-" xlink:href="#cd-N10" /><directedNode xlink:href="#cd-N11" /><curveProperty><Curve srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 47 6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge orientation="-" xlink:href="#cd-E18" /></Face></directedFace></TopoSurface>
