[postgis-tickets] [PostGIS] #3550: postgis crashes postgresql backend
trac at osgeo.org
Wed May 11 06:05:38 PDT 2016
Reporter: vvk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Keywords: |
We're using postgis with postgresql and we're getting crashes after
upgrade from 9.3 to 9.4 due to postgis.
Postgres log:
2016-05-04 09:10:53 YEKT::@:[2870]: LOG: server process (PID 10844) was
terminated by signal 11: Segmentation fault
2016-05-04 09:10:53 YEKT::@:[2870]: DETAIL: Failed process was running:
autovacuum: VACUUM ANALYZE public.device_summary
2016-05-04 09:10:53 YEKT::@:[2870]: LOG: terminating any other active
server processes
Versions:
PostgreSQL 9.4.7 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
4.8.2-19ubuntu1) 4.8.2, 64-bit POSTGIS="2.2.2 r14797"
GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.10.1, released 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" (core procs
from "2.2.1 r14555" need upgrade) TOPOLOGY (topology procs from "2.2.1
r14555" need upgrade) RASTER (raster procs from "2.2.1 r14555" need
upgrade)
backtrace:
#0 nd_box_array_distribution (distribution=0x7ffc0cf482b0,
ndims=<optimized out>, extent=0x7ffc0cf48270, num_boxes=29229,
nd_boxes=0x7f1475045260) at gserialized_estimate.c:750
#1 compute_gserialized_stats_mode (stats=stats at entry=0x7f1474dc36f0,
fetchfunc=fetchfunc at entry=0x7f147306b970 <std_fetch_func>,
sample_rows=sample_rows at entry=30000, total_rows=total_rows at entry=2500090,
mode=mode at entry=2) at gserialized_estimate.c:1471
#2 0x00007f125d336b79 in compute_gserialized_stats (stats=0x7f1474dc36f0,
fetchfunc=0x7f147306b970 <std_fetch_func>, sample_rows=30000,
total_rows=2500090) at gserialized_estimate.c:1731
#3 0x00007f147306e6f1 in do_analyze_rel
(onerel=onerel at entry=0x7f1472e87100, acquirefunc=<optimized out>,
relpages=93536, inh=inh at entry=0 '\000',
in_outer_xact=in_outer_xact at entry=0 '\000',
elevel=elevel at entry=13, vacstmt=0x7ffc0cf489f0,
vacstmt=0x7ffc0cf489f0) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/commands/analyze.c:531
#4 0x00007f147306f5bd in analyze_rel (relid=relid at entry=19103,
vacstmt=vacstmt at entry=0x7ffc0cf489f0, in_outer_xact=<optimized out>,
bstrategy=<optimized out>)
at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/commands/analyze.c:269
#5 0x00007f14730c2e80 in vacuum (vacstmt=vacstmt at entry=0x7ffc0cf489f0,
relid=<optimized out>, do_toast=do_toast at entry=0 '\000',
bstrategy=<optimized out>, bstrategy at entry=0x7f1474e05af0,
for_wraparound=0 '\000', isTopLevel=isTopLevel at entry=1 '\001') at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/commands/vacuum.c:266
#6 0x00007f147315d5e8 in autovacuum_do_vac_analyze
(bstrategy=0x7f1474e05af0, tab=0x7f1474e05c00) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/autovacuum.c:2856
#7 do_autovacuum () at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/autovacuum.c:2368
#8 0x00007f147315db13 in AutoVacWorkerMain (argv=0x0, argc=0) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/autovacuum.c:1702
#9 0x00007f147315dbe9 in StartAutoVacWorker () at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/autovacuum.c:1487
#10 0x00007f147316ad8a in StartAutovacuumWorker () at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/postmaster.c:5373
#11 sigusr1_handler (postgres_signal_arg=<optimized out>) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/postmaster.c:5027
#12 <signal handler called>
#13 0x00007f14712a9d83 in __select_nocancel () at ../sysdeps/unix/syscall-
template.S:81
#14 0x00007f1472f908ec in ServerLoop () at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/postmaster.c:1643
#15 0x00007f147316bedb in PostmasterMain (argc=5, argv=<optimized out>) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/postmaster/postmaster.c:1287
#16 0x00007f1472f920ad in main (argc=5, argv=0x7f1474cda1a0) at
/build/postgresql-9.4-gA1vrE/postgresql-9.4-9.4.7/build/../src/backend/main/main.c:233
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3550>
