[postgis-tickets] r14916 - Correction to doc for ST_GeomFromText (it accepts SRIDs not defined in spatial_ref_sys)
Daniel Baston
dbaston at gmail.com
Tue May 24 17:49:06 PDT 2016
Author: dbaston
Date: 2016-05-24 17:49:06 -0700 (Tue, 24 May 2016)
New Revision: 14916
trunk/doc/reference_constructor.xml
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml 2016-05-22 21:15:48 UTC (rev 14915)
+++ trunk/doc/reference_constructor.xml 2016-05-25 00:49:06 UTC (rev 14916)
@@ -907,10 +907,10 @@
<!-- optionally mention that this function uses indexes if appropriate -->
<note>
- <para>There are 2 variants of ST_GeomFromText function, the first takes no SRID and returns a geometry
- with no defined spatial reference system. The second takes a spatial reference id as the second argument
- and returns an ST_Geometry that includes this srid as part of its meta-data. The srid must be defined
- in the spatial_ref_sys table.</para>
+ <para>There are two variants of ST_GeomFromText function. The first takes no SRID and returns a geometry
+ with no defined spatial reference system (SRID=0). The second takes a SRID as the second argument
+ and returns a geometry that includes this SRID as part of its metadata.
+ </para>
</note>
<para>&sfs_compliant; s3.2.6.2 - option SRID is from the conformance suite.</para>
