[postgis-tickets] r14917 - Edits to ST_MakePolygon doc
Daniel Baston
dbaston at gmail.com
Tue May 24 17:56:30 PDT 2016
Author: dbaston
Date: 2016-05-24 17:56:30 -0700 (Tue, 24 May 2016)
New Revision: 14917
trunk/doc/reference_constructor.xml
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml 2016-05-25 00:49:06 UTC (rev 14916)
+++ trunk/doc/reference_constructor.xml 2016-05-25 00:56:30 UTC (rev 14917)
@@ -1628,7 +1628,7 @@
<para>Creates a Polygon formed by the given shell. Input
geometries must be closed LINESTRINGS. Comes in 2 variants.</para>
- <para>Variant 1: takes one closed linestring.</para>
+ <para>Variant 1: Takes one closed linestring.</para>
<para>Variant 2: Creates a Polygon formed by the given shell and array of
holes. You can construct a geometry array using ST_Accum or the PostgreSQL ARRAY[] and
ARRAY() constructs. Input geometries must be closed LINESTRINGS.</para>
@@ -1666,7 +1666,7 @@
</programlisting>
</refsection>
<refsection>
- <title>Examples: Outter shell with inner shells</title>
+ <title>Examples: Outer shell with inner shells</title>
<para>Build a donut with an ant hole</para>
<programlisting>
@@ -1682,11 +1682,11 @@
</programlisting>
<para>Build province boundaries with holes
representing lakes in the province from a set of
- province polygons/multipolygons and water line strings
- this is an example of using PostGIS ST_Accum
- <note><para>The use of CASE because feeding a null array into
- ST_MakePolygon results in NULL</para></note>
- <note><para>the use of left join to guarantee we get all provinces back even if they have no lakes</para></note></para>
+ province polygons/multipolygons and water linestrings.
+ This is an example of using PostGIS ST_Accum.
+ <note><para>The CASE construct is used because feeding a null array into
+ ST_MakePolygon results in NULL.</para></note>
+ <note><para>A left join is used to guarantee we get all provinces back even if they have no lakes.</para></note></para>
<programlisting>
SELECT p.gid, p.province_name,
CASE WHEN
