[postgis-tickets] r14918 - #3565, st_setpoint crashes database
Paul Ramsey pramsey at cleverelephant.ca
Wed May 25 10:28:18 PDT 2016
Author: pramsey
Date: 2016-05-25 10:28:18 -0700 (Wed, 25 May 2016)
New Revision: 14918
   branches/2.0/NEWS
   branches/2.0/postgis/lwgeom_functions_basic.c
   branches/2.0/regress/tickets.sql
   branches/2.0/regress/tickets_expected
Modified: branches/2.0/NEWS
--- branches/2.0/NEWS	2016-05-25 00:56:30 UTC (rev 14917)
+++ branches/2.0/NEWS	2016-05-25 17:28:18 UTC (rev 14918)
@@ -21,6 +21,7 @@
   - #3436, memory handling mistake in ptarray_clone_deep
   - #3461, ST_GeomFromKML crashes Postgres when there are
            innerBoundaryIs and no outerBoundaryIs
+  - #3565, ST_SetPoint can crash backend
 PostGIS 2.0.7
Modified: branches/2.0/postgis/lwgeom_functions_basic.c
--- branches/2.0/postgis/lwgeom_functions_basic.c	2016-05-25 00:56:30 UTC (rev 14917)
+++ branches/2.0/postgis/lwgeom_functions_basic.c	2016-05-25 17:28:18 UTC (rev 14918)
@@ -2287,6 +2287,11 @@
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
+	if ( lwgeom_is_empty(lwg) )
+		elog(ERROR, "Cannot set point values on EMPTY geometry, use ST_AddPoint to add points");
+		PG_RETURN_NULL();
 	if ( which > line->points->npoints-1 )
 		elog(ERROR, "Point index out of range (%d..%d)", 0, line->points->npoints-1);
Modified: branches/2.0/regress/tickets.sql
--- branches/2.0/regress/tickets.sql	2016-05-25 00:56:30 UTC (rev 14917)
+++ branches/2.0/regress/tickets.sql	2016-05-25 17:28:18 UTC (rev 14918)
@@ -774,5 +774,8 @@
 SELECT '#2870', ST_Summary('Point(151.215289 -33.856885)'::geometry::bytea::geography);
+-- #3565
+SELECT '#3565',ST_SetPoint(st_geomfromtext('LINESTRING EMPTY'), 0, ST_MakePoint(1,1));
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: branches/2.0/regress/tickets_expected
--- branches/2.0/regress/tickets_expected	2016-05-25 00:56:30 UTC (rev 14917)
+++ branches/2.0/regress/tickets_expected	2016-05-25 17:28:18 UTC (rev 14918)
@@ -244,3 +244,4 @@
 #2427|POINT(-1 0)
 #2168|5340.76237395|5340.76237395|0
 #2870|Point[G]
+ERROR:  Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
