[postgis-tickets] r14919 - #3565, st_setpoint crashes database
Paul Ramsey
pramsey at cleverelephant.ca
Wed May 25 10:28:25 PDT 2016
Author: pramsey
Date: 2016-05-25 10:28:25 -0700 (Wed, 25 May 2016)
New Revision: 14919
branches/2.1/NEWS
branches/2.1/postgis/lwgeom_functions_basic.c
branches/2.1/regress/tickets.sql
branches/2.1/regress/tickets_expected
Modified: branches/2.1/NEWS
--- branches/2.1/NEWS 2016-05-25 17:28:18 UTC (rev 14918)
+++ branches/2.1/NEWS 2016-05-25 17:28:25 UTC (rev 14919)
@@ -27,6 +27,7 @@
innerBoundaryIs and no outerBoundaryIs
- #3429, upgrading to 2.2 or 2.3 can cause crash/hang on some
platforms
+ - #3565, ST_SetPoint can crash backend
PostGIS 2.1.8
Modified: branches/2.1/postgis/lwgeom_functions_basic.c
--- branches/2.1/postgis/lwgeom_functions_basic.c 2016-05-25 17:28:18 UTC (rev 14918)
+++ branches/2.1/postgis/lwgeom_functions_basic.c 2016-05-25 17:28:25 UTC (rev 14919)
@@ -2330,6 +2330,11 @@
elog(ERROR, "First argument must be a LINESTRING");
PG_RETURN_NULL();
+ if ( lwgeom_is_empty(lwg) )
+ elog(ERROR, "Cannot set point values on EMPTY geometry, use ST_AddPoint to add points");
+ PG_RETURN_NULL();
if ( which > line->points->npoints-1 )
elog(ERROR, "Point index out of range (%d..%d)", 0, line->points->npoints-1);
Modified: branches/2.1/regress/tickets.sql
--- branches/2.1/regress/tickets.sql 2016-05-25 17:28:18 UTC (rev 14918)
+++ branches/2.1/regress/tickets.sql 2016-05-25 17:28:25 UTC (rev 14919)
@@ -883,5 +883,8 @@
SELECT '#3375', ST_AsText(ST_RemoveRepeatedPoints('GEOMETRYCOLLECTION(POINT(1 1))'::geometry));
+-- #3565
+SELECT '#3565',ST_SetPoint(st_geomfromtext('LINESTRING EMPTY'), 0, ST_MakePoint(1,1));
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: branches/2.1/regress/tickets_expected
--- branches/2.1/regress/tickets_expected 2016-05-25 17:28:18 UTC (rev 14918)
+++ branches/2.1/regress/tickets_expected 2016-05-25 17:28:25 UTC (rev 14919)
@@ -261,3 +261,4 @@
#2870|Point[GS]
#3367|POLYGON EMPTY
#3375|GEOMETRYCOLLECTION(POINT(1 1))
+ERROR: Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
