[postgis-tickets] r14920 - #3565, st_setpoint crashes database
Paul Ramsey pramsey at cleverelephant.ca
Wed May 25 10:28:32 PDT 2016
Author: pramsey
Date: 2016-05-25 10:28:32 -0700 (Wed, 25 May 2016)
New Revision: 14920
   branches/2.2/NEWS
   branches/2.2/postgis/lwgeom_functions_basic.c
   branches/2.2/regress/tickets.sql
   branches/2.2/regress/tickets_expected
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2016-05-25 17:28:25 UTC (rev 14919)
+++ branches/2.2/NEWS	2016-05-25 17:28:32 UTC (rev 14920)
@@ -6,6 +6,7 @@
   - #3524, Add interruptibility to geography brute-force distance
            calculation
   - #3522, Handle POINT and MULTIPOINT correctly in ST_Subdivide
+  - #3565, ST_SetPoint can crash backend
 PostGIS 2.2.2
Modified: branches/2.2/postgis/lwgeom_functions_basic.c
--- branches/2.2/postgis/lwgeom_functions_basic.c	2016-05-25 17:28:25 UTC (rev 14919)
+++ branches/2.2/postgis/lwgeom_functions_basic.c	2016-05-25 17:28:32 UTC (rev 14920)
@@ -2265,6 +2265,11 @@
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
+	if ( lwgeom_is_empty(lwg) )
+		elog(ERROR, "Cannot set point values on EMPTY geometry, use ST_AddPoint to add points");
+		PG_RETURN_NULL();
 	if ( which > line->points->npoints-1 )
 		elog(ERROR, "Point index out of range (%d..%d)", 0, line->points->npoints-1);
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql	2016-05-25 17:28:25 UTC (rev 14919)
+++ branches/2.2/regress/tickets.sql	2016-05-25 17:28:32 UTC (rev 14920)
@@ -947,5 +947,8 @@
 SELECT '#3470', ST_Polygonize(ARRAY[NULL]::geometry[]) IS NULL;
 SELECT '#3470b', ST_Area(ST_Polygonize(ARRAY[NULL, 'LINESTRING (0 0, 10 0, 10 10)', NULL, 'LINESTRING (0 0, 10 10)', NULL]::geometry[]));
+-- #3565
+SELECT '#3565',ST_SetPoint(st_geomfromtext('LINESTRING EMPTY'), 0, ST_MakePoint(1,1));
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected	2016-05-25 17:28:25 UTC (rev 14919)
+++ branches/2.2/regress/tickets_expected	2016-05-25 17:28:32 UTC (rev 14920)
@@ -291,3 +291,4 @@
 #3437e|5
 #3470|t
 #3470b|50
+ERROR:  Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
