[postgis-tickets] r15233 - Remove trailing whitespaces
Sandro Santilli
strk at kbt.io
Wed Nov 16 23:57:04 PST 2016
Author: strk
Date: 2016-11-16 23:57:04 -0800 (Wed, 16 Nov 2016)
New Revision: 15233
trunk/doc/extras_topology.xml
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml 2016-11-17 07:56:57 UTC (rev 15232)
+++ trunk/doc/extras_topology.xml 2016-11-17 07:57:04 UTC (rev 15233)
@@ -412,15 +412,15 @@
<para><xref linkend="AddTopoGeometryColumn"/></para>
</refsection>
</refentry>
<refentry id="Populate_Topology_Layer">
<refnamediv>
<refname>Populate_Topology_Layer</refname>
<refpurpose>Adds missing entries to topology.layer table by reading metadata from topo tables.</refpurpose>
</refnamediv>
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
@@ -449,18 +449,18 @@
CREATE TABLE strk.parcels(gid serial, parcel_id varchar(20) PRIMARY KEY, address text);
SELECT topology.AddTopoGeometryColumn('strk_topo', 'strk', 'parcels', 'topo', 'POLYGON');
-- this will return no records because this feature is already registered
-SELECT *
- FROM topology.Populate_Topology_Layer();
+SELECT *
+ FROM topology.Populate_Topology_Layer();
-- let's rebuild
TRUNCATE TABLE topology.layer;
-SELECT *
+SELECT *
SELECT topology_id,layer_id, schema_name As sn, table_name As tn, feature_column As fc
FROM topology.layer;
</programlisting>
<screen> schema_name | table_name | feature_column
