[postgis-tickets] r15234 - Update topology slide deck url
Sandro Santilli
strk at kbt.io
Wed Nov 16 23:57:12 PST 2016
Author: strk
Date: 2016-11-16 23:57:11 -0800 (Wed, 16 Nov 2016)
New Revision: 15234
trunk/doc/extras_topology.xml
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml 2016-11-17 07:57:04 UTC (rev 15233)
+++ trunk/doc/extras_topology.xml 2016-11-17 07:57:11 UTC (rev 15234)
@@ -2,7 +2,7 @@
<chapter id="Topology">
<title>Topology</title>
<para>The PostGIS Topology types and functions are used to manage topological objects such as faces, edges and nodes. </para>
- <para>Sandro Santilli's presentation at PostGIS Day Paris 2011 conference gives a good synopsis of PostGIS Topology and where it is headed <ulink url="http://strk.keybit.net/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf">Topology with PostGIS 2.0 slide deck</ulink>.</para>
+ <para>Sandro Santilli's presentation at PostGIS Day Paris 2011 conference gives a good synopsis of PostGIS Topology and where it is headed <ulink url="http://strk.kbt.io/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf">Topology with PostGIS 2.0 slide deck</ulink>.</para>
<para>Vincent Picavet provides a good synopsis and overview of what is Topology, how is it used, and various FOSS4G tools that support it in <ulink url="https://github.com/Oslandia/presentations/blob/master/pgconf_eu_2012/pgconfeu2012_vincent_picavet_postgis_topology.pdf?raw=true">PostGIS Topology PGConf EU 2012</ulink>.</para>
<para>An example of a topologically based GIS database is the <ulink url="https://www.census.gov/geo/maps-data/data/tiger.html">US Census Topologically Integrated Geographic Encoding and Referencing System (TIGER)</ulink> database. If you want to experiment with PostGIS topology and need some data, check out <xref linkend="Topology_Load_Tiger" />.</para>
<para>The PostGIS topology module has existed in prior versions of PostGIS but was never part of the Official PostGIS documentation.
