[postgis-tickets] r15235 - Backport trunk changes in topology docs
Sandro Santilli
strk at kbt.io
Thu Nov 17 00:01:03 PST 2016
Author: strk
Date: 2016-11-17 00:01:03 -0800 (Thu, 17 Nov 2016)
New Revision: 15235
branches/2.3/doc/extras_topology.xml
Modified: branches/2.3/doc/extras_topology.xml
--- branches/2.3/doc/extras_topology.xml 2016-11-17 07:57:11 UTC (rev 15234)
+++ branches/2.3/doc/extras_topology.xml 2016-11-17 08:01:03 UTC (rev 15235)
@@ -2,7 +2,7 @@
<chapter id="Topology">
<title>Topology</title>
<para>The PostGIS Topology types and functions are used to manage topological objects such as faces, edges and nodes. </para>
- <para>Sandro Santilli's presentation at PostGIS Day Paris 2011 conference gives a good synopsis of PostGIS Topology and where it is headed <ulink url="http://strk.keybit.net/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf">Topology with PostGIS 2.0 slide deck</ulink>.</para>
+ <para>Sandro Santilli's presentation at PostGIS Day Paris 2011 conference gives a good synopsis of PostGIS Topology and where it is headed <ulink url="http://strk.kbt.io/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf">Topology with PostGIS 2.0 slide deck</ulink>.</para>
<para>Vincent Picavet provides a good synopsis and overview of what is Topology, how is it used, and various FOSS4G tools that support it in <ulink url="https://github.com/Oslandia/presentations/blob/master/pgconf_eu_2012/pgconfeu2012_vincent_picavet_postgis_topology.pdf?raw=true">PostGIS Topology PGConf EU 2012</ulink>.</para>
<para>An example of a topologically based GIS database is the <ulink url="https://www.census.gov/geo/maps-data/data/tiger.html">US Census Topologically Integrated Geographic Encoding and Referencing System (TIGER)</ulink> database. If you want to experiment with PostGIS topology and need some data, check out <xref linkend="Topology_Load_Tiger" />.</para>
<para>The PostGIS topology module has existed in prior versions of PostGIS but was never part of the Official PostGIS documentation.
@@ -412,15 +412,15 @@
<para><xref linkend="AddTopoGeometryColumn"/></para>
</refsection>
</refentry>
<refentry id="Populate_Topology_Layer">
<refnamediv>
<refname>Populate_Topology_Layer</refname>
<refpurpose>Adds missing entries to topology.layer table by reading metadata from topo tables.</refpurpose>
</refnamediv>
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
@@ -449,18 +449,18 @@
CREATE TABLE strk.parcels(gid serial, parcel_id varchar(20) PRIMARY KEY, address text);
SELECT topology.AddTopoGeometryColumn('strk_topo', 'strk', 'parcels', 'topo', 'POLYGON');
-- this will return no records because this feature is already registered
-SELECT *
- FROM topology.Populate_Topology_Layer();
+SELECT *
+ FROM topology.Populate_Topology_Layer();
-- let's rebuild
TRUNCATE TABLE topology.layer;
-SELECT *
+SELECT *
SELECT topology_id,layer_id, schema_name As sn, table_name As tn, feature_column As fc
FROM topology.layer;
</programlisting>
<screen> schema_name | table_name | feature_column
@@ -2510,7 +2510,11 @@
<!-- Optionally add a "See Also" section -->
<refsection>
<title>See Also</title>
- <para><xref linkend="CreateTopology"/>, <xref linkend="spatial_ref_sys"/></para>
+ <para>
+<xref linkend="TopoGeo_AddLineString"/>,
+<xref linkend="CreateTopology"/>,
+<xref linkend="spatial_ref_sys"/>
+ </para>
</refsection>
</refentry>
