[postgis-tickets] [PostGIS] #3501: [raster] add raster constraint max extent exceeds array size limit
trac at osgeo.org
Sun Nov 20 13:23:03 PST 2016
Reporter: hypostase | Owner: dustymugs
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.3
Component: raster | Version: 2.2.x
Resolution: | Keywords:
Comment (by avernar):
I did some tests on my database. I have 3 raster tables and ran each
method on them.
Rows st_extent st_collect st_union st_memunion
19,575,700 30:15 failed failed 480:00+
3,137,060 5:05 5:10 18:35 not tested
379,320 0:15.9 0:15.9 0:43.9 15:00+
All times in minutes:seconds and are just for the first select to get the
ewkt. So in my case st_extent and st_collect are roughly the same,
st_union is around 3x slower and st_memunion is ridiculously slow and were
aborted at the times listed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3501#comment:9>
