[postgis-tickets] [PostGIS] #3501: [raster] add raster constraint max extent exceeds array size limit
trac at osgeo.org
Sun Nov 20 20:04:58 PST 2016
Reporter: hypostase | Owner: dustymugs
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.3
Component: raster | Version: 2.2.x
Resolution: | Keywords:
Comment (by avernar):
Ah, makes sense not using ST_Transform then if it would just fail the
validation later anyways.
As for ST_Collect being faster I just noticed the note in
[http://postgis.refractions.net/documentation/manual-svn/ST_Collect.html].
It's still surprising there's that much of a difference when dealing with
simple bounding boxes between the two.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3501#comment:11>
