[postgis-tickets] r15247 - Incorrect parameter name for CreateTopology
Regina Obe lr at pcorp.us
Sat Nov 26 06:59:52 PST 2016
Author: robe
Date: 2016-11-26 06:59:52 -0800 (Sat, 26 Nov 2016)
New Revision: 15247
   trunk/doc/extras_topology.xml
references #3509 for 2.4.0 (trunk)
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml	2016-11-26 14:55:51 UTC (rev 15246)
+++ trunk/doc/extras_topology.xml	2016-11-26 14:59:52 UTC (rev 15247)
@@ -668,14 +668,14 @@
 						<funcdef>integer <function>CreateTopology</function></funcdef>
 						<paramdef><type>varchar </type> <parameter>topology_schema_name</parameter></paramdef>
 						<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>
-						<paramdef><type>double precision </type> <parameter>tolerance</parameter></paramdef>
+						<paramdef><type>double precision </type> <parameter>prec</parameter></paramdef>
 					</funcprototype>
 					<funcprototype>
 						<paramdef><type>boolean </type> <parameter>hasz</parameter></paramdef>
 					</funcprototype>
 				</funcsynopsis>
@@ -686,7 +686,7 @@
                 <para>Creates a new schema with name <varname>topology_name</varname> consisting of tables (<varname>edge_data</varname>,<varname>face</varname>,<varname>node</varname>, <varname>relation</varname>
                     and registers this new topology in the topology.topology table. It returns the id of the topology in the topology table. The srid is the spatial reference identified as
-                defined in spatial_ref_sys table for that topology.  Topologies must be uniquely named.  The tolerance is measured in the units of the spatial reference system.  If the tolerance is not specified defaults to 0.</para>
+                defined in spatial_ref_sys table for that topology.  Topologies must be uniquely named.  The tolerance is measured in the units of the spatial reference system.  If the tolerance (<varname>prec</varname>) is not specified defaults to 0.</para>
                 <para>This is similar to the SQL/MM <xref linkend="ST_InitTopoGeo" /> but a bit more functional.  <varname>hasz</varname> defaults to false if not specified.</para>
