[postgis-tickets] r15253 - ST_DumpAsPolygons documentation confusing wrt no data value
Regina Obe
lr at pcorp.us
Sat Nov 26 08:39:38 PST 2016
Author: robe
Date: 2016-11-26 08:39:38 -0800 (Sat, 26 Nov 2016)
New Revision: 15253
branches/2.3/doc/reference_raster.xml
closes #3512 for PostGIS 2.3.1
Modified: branches/2.3/doc/reference_raster.xml
--- branches/2.3/doc/reference_raster.xml 2016-11-26 16:39:06 UTC (rev 15252)
+++ branches/2.3/doc/reference_raster.xml 2016-11-26 16:39:38 UTC (rev 15253)
@@ -12811,7 +12811,7 @@
can be used to expand a single raster into multiple POLYGONS/MULTIPOLYGONS.</para>
<para>Availability: Requires GDAL 1.7 or higher.</para>
- <note><para>If there is a no data value set for a band, pixels with that value will not be returned.</para></note>
+ <note><para>If there is a no data value set for a band, pixels with that value will not be returned except in the case of exclude_nodata_value=false.</para></note>
<note><para>If you only care about count of pixels with a given value in a raster, it is faster to use <xref linkend="RT_ST_ValueCount" />.</para></note>
<note>
<para>
